LED reverse light. Found a great replacement for $11 at Harbor Freight
dragonman
Mason city, Iowa
aw113sgte
1,305
La Crosse, WI
Would it be possible to add a switch on the dash to turn this on with out being in reverse ?
Of course! However if you just sent the 24v to the same wire, the backup beeper would also sound (I've read they are on the same wire but I also don't have the wiring diagrams to verify). You could just use a diode to prevent this.
