Staffsargent
- 1
- 18
- Blakeslee, PA
What would SAE 10 motor oil be use for?
Use this for your hydraulics, it's viscosity is equivalent to 10 weight motor oil.Recovry4x4 said:Wished I could find a drum of SAE 10 for really cheap.
so this is what should be used in the 5T power steering pumps?cranetruck said:Use this for your hydraulics, it's viscosity is equivalent to 10 weight motor oil.Recovry4x4 said:Wished I could find a drum of SAE 10 for really cheap.
Your local NAPA, Carquest or farm store will also carry AW32 hydraulic fluid, which has the viscosity of 10 weight engine oil, which I use for my crane.
Best "fit" I have found, so that's what I'll use.jwaller said:so this is what should be used in the 5T power steering pumps?cranetruck said:Use this for your hydraulics, it's viscosity is equivalent to 10 weight motor oil.Recovry4x4 said:Wished I could find a drum of SAE 10 for really cheap.
