majortom
- 21
- 0
- Aniwa, Wisconsin
Saturday the high temp was -7 and she got down to 20 below last night. Perfect weather to find out how good your truck runs, I always like to try to operate a truck under severe conditions so that the day i need it i know it will work, if your not familiar with ten tons its 9' 1/2' wide 30000+ pounds and has a 8cylndar Cummings diesel in it starting the truck was pretty interesting, flipped the ignition on, pulled the hand throttle out 1/3 switched on the glowplug count to Mississippi 20, pushed the start button with the left hand while pumping the fuel priming pump with the right hand and saying a short prayer. the engine started tremendous clouds of smoke, and hammering like its going to explode, had to keep pumping the primer for about 5 minutes, The engine would finally run without stalling at 1/3 throttle even with the arctic front installed it took over an hour for the temperature gage to move. Another half hour and we had some form of heat blowing out of the heater... Did i mention that the truck tried to drive away in neutral due to the thickness of the transmission fluid, trying to drive the truck was quite interesting as making shifts, regardless how many times you clutched it was really tricky, but the big problem was that if you touched the break petal the tires just stopped and the truck just kept sliding, if you gave it too much throttle in any gear the tires just spin its pretty impressive how fast you can whip one of these around in a circle, i did several donuts and deiced to stop before i smashed a building,.. way to much fun.
