1031 to shelter carrier dually conversion
TGP (IL)
33
Metro East IL
Yeah Gimp, if you don't mind. Tom, the 14 bolt was only used in dually pickups after the 88/91 body change.
Well that explains it for me.
I was referring to the square body trucks (73-87).
Don't know much about the GM trucks after the model change in 88,91 for one tons and suburban's.
After I saw GM went to Independent Front suspension, I knew I bought my last new GM truck.
Tom
HillbillyWizard
14
Halifax, PA
Hoping one of you gents might have the answer to my problem... M1028A3 or M1028A2 dually adapters used a 5/8-18 stud (not the studs in the hub, but the studs in the adapter) with a very large knurl about .868" to .870"
Does anyone know where to find this stud or even a P/N? I need just one to replace a broken one.
Sharecropper
954
Paris KY
John I get all that kind of stuff from McMaster Carr. Google them and they will pop right up.
Hope this helps.
P.S. - I am still looking for a good pair of CUCV front fenders.
HillbillyWizard
14
Halifax, PA
Hope this helps.
Thanks, but I already tried there. Dorman doesn't make them, tried a few other places too. I can't even find the P/N because from what I see they weren't put in the -34P manual.
HillbillyWizard
14
Halifax, PA
Bad news if someone finds this thread looking for the stud I was looking for... But here was my solution. Bought a stud with the large knurl and machined it into the stud I needed. IMG_20200308_213343499.jpgIMG_20200308_213655337.jpg
