14 bolt woes
DieselStax
Cogan Station, Pa
2 of the 8 bolts that hold the end of my axle shaft to my hub are striped, my question is can I drive it to my friend who's a mechanist so he can tap the threads? I have 6 of the 8 bolts in, and will gear oil leak out of my rear or not? Thank you
Moto4Life
Lancaster/Davis CA
6 bolts should last you for a short drive without any problems as long as you take it easy. If you're worried about oil leaking out you could always remove the rest of the bolts, slide the axle out a little and put some RTV on the mating surface for peace of mind.
Skinny
492
Portsmouth, NH
I think any high grade fastener should work, I don't think you would need OEM bolts.
Like CUCVNUT suggested, a junkyard hub would be a quick repair.
doghead
4 Star General /Moderator
1,184
NY
From his description, I can't tell if his bolts are stripped or the threads in the holes are.
Either way, I doubt the hub needs to be removed to fix it.
DieselStax
Cogan Station, Pa
Thanks guys I fixed it today, the threads in two of the holes just were chewed up and I really didn't want to pull the hub off because I just put new bearings and races and a oil seal in it and didn't feel like tearing her apart again. But I just ran a tap through them a couple of times and she's as good as new.
