2.5 ton axles under a 5 ton truck
wehring
26
Angleton, TX
I know this seems backwards but has anyone done this? There is a good idea behind the question...
Justin Wehring
979 997 3112
maddawg308
746
Front Royal, VA
I wouldn't. The 5-ton is a LOT heavier than a 2.5-ton truck. Those axles would be under a lot of stress and for safety's sake, I would not chance it.
It would be kinda like the guy who had a few cases of beer and did this:
maddawg308
746
Front Royal, VA
No. And as long as people keep bringing up the subject of swapping axles for smaller ones, or ugly truck contests, it will keep re-appearing to remind people that an MV should never go to waste like this.
Jakob
Louisville, KY
If you have a 5-ton with robbed axles; had it ever came up about using axles from an OTR truck? You wouldn't have 6x6, but you'd have a good set of axles, higher gears, 10-bolt hubs and probably better brakes.
