JDToumanian said:
The boots from Ted Hils had the zipper both sewn and riveted to the rubber, whereas Saturn's do not have the rivets. They didn't looks any better though. Jon
The last boot I got from Saturn did have rivets, an earlier one from Saturn did not. maybe they have changed suppliers.
In any event when replacing an axle boot on a Deuce, THE INNER CLAMP BOLT MUST BE INSTALLED AT THE TOP OF THE KNUCKLE! If you install the clamp bolt toward the front as shown in the picture in the TM, the knuckle will push the clamp off the axle housing and you get to install the boot all over again (ask me how I know).
Also, do not bend the inner clamp bolt to prevent it from loosening. Instead, replace the clamp nut with a self locking nut. If your clamp came with a metric bolt & nut (like mine), go to your local hardware store and buy a US size bolt and lock nut. The metric and US sizes do not match up exactly, so buy the next larger diameter and next longer US bolt, they will work just fine. Do NOT buy a bolt shorter than that which came with the clamp, you will need the extra length to get the nut started on the bolt. A shorter bolt will require about six arms to pull everything tight enough to start the nut (ask me how I know).
I repeat these warnings on every knuckle boot thread that I see, just so no none else has to install their boot three times before they get it right like I had to!
