Or you could just run the thing off a 5gal jerry can(with gas in it)!If you have a gasoline truck, I have a complete, new in the crate, fuel fired heater / winterization kit (it has a winterfront for the grill, too).
It will keep you warm. In Alaska. In the winter. In Barrow.
PM if you are interested.
Storm 51
That is how I have my truck now, the jerry can on the drivers step feeds my heater, works great and like said they don't use very much fuel per hour of run time so using mine ALL the time it still takes me 2 weeks to run it down enough to have to put more in the can. If you don't drive your truck very much 5 gallons might last you a month or 2.Or you could just run the thing off a 5gal jerry can(with gas in it)!
Thanks for the link, got it bookmarked. I might send you a pm about it after I get my deuce, just started looking for one.Sure. It doesn't care where the gas comes from as long as it gets the gas. I've even seen these things installed with a little gas tank on the left front fender. The heater itself mounts inside the engine compartment (or you can mount it any where you want). It has its own metal box to live in. It uses about an eighth of a gallon an hour.
All the information on these kits and their installation is contained in the following manual:
TM 9-2320-209-35, Change 1, page 316, Para 354.
Below is a web address where you can read the installation instructions and see wiring diagrams, pictures, drawings and detailed specifications. I would copy the material, but it is a Google book, so you can't download it.
http://books.google.com/books?id=8CkYAAAAYAAJ&pg=PA316&lpg=PA316&dq=2540-570-1356&source=bl&ots=Z5I5oADqXr&sig=VXsorqI3Ysj7i97qRXeIbcwp_40&hl=en&sa=X&ei=wwLnUqKLIJDzoATQg4G4Ag&ved=0CDcQ6AEwAg#v=onepage&q=2540-570-1356&f=false
Hope this helps. Let me know if you have any questions.
Storm 51
don't care what your heater says, 1080 watts, 24 volt x 45 amps, is 3685 btu/hr. you will be very cold. for the electric heater to be 18,000 btu at 24 volt, it would have to draw 219 amps.
for your heater to be 18,000 btu it would have to be 5274 watts and that is 24 volts x 219 amps approx
The stock heaters are OK when they are installed correctly, some were/are not.Right, overcompensation just to get a comfortable level in the deuce. How bad are the stock heaters? If you were to put a BTU rating on them? I haven't read much about the water heater units, how do the stock heaters work? Are they electric or water? Of course where I'm at the average temperature in the winter is probably 32. It does get down to 0 once or twice but not that bad usually. This year's been a little colder.
Only if you want to go to sleep when you drive, if you can't find any other way, a generator in the bed with a 120v heater in the cab works well. I did that on a -6 deg. day for a 923a2 recovery.I thought about just getting a propane heater and setting it on the floor on the passenger side. Probably not the best idea, or maybe keeping it in the bed and piping it through the cab window.
