- 2,960
- 30
- 48
- Tiro, Ohio
This is a long one, was even a longer day. Am towing my camper to haspin. Last year I used a 24v bulb in my magnetic towing light set. Had to rewire it because the 24v bulb elements are reversed from the 12v bulb.
I lost the 24v bulbs, and at 11.00 a piece from napa, they are not cheap. In a time crunch, so didn't want to order anything and have to wait. On the web, a couple of places offer them for 2.00 and less. Plus I would have to buy a second magnetic light set, that way I don't have to rewire my only set every time I used it on the deuce. (another 50 bucks.. GRRRR.)
I am not very familiar with electronics, so I called a couple of guys. Thought about adding a second set of lights in series to reduce the voltage, but the bulbs share grounds. Would end up with about 8 lights to get it to work!
So we ended up with some IC voltage regulators. They are good to 5 amps, and reduce voltages up to 30 volts to 12v. Expensive at 25 a piece. Bought 3, one for tail lights, one for left turn, and one for right turn. They ground through the case. Part # NTE933.
Made up a small box for them, so I could seal it. This is a first for me, so may not be to standard wiring! And you can see why I need a trailer plug.
Wired it up, and OMG, it works! Only thing is on hazard lights, only one side blinks. Think it needs a diode somewhere for that. Tail and blinkers work, haven't tried brake yet.
First pic is of plug, second one is lights, Third one I tried to show the back of the regulators, and wiring. Fourth one is the box I used. Still need to seal it up, and add cover over the regulators.
Feel free to point out what may need fixed yet, as I said, I am no expert at this.
Dennis
Dennis
