gringeltaube said:Heavy? Do you mean heavy duty? What do you want it for?What’s wrong with the std. front plus rear output PTO (model WND-7-2 for the deuce trannys? It should be strong enough to move any hydraulic pump or similar equipment for a dumper or crane at engine rpm plus 10%, same rotation. According to the manual both models WN-7-28 and WND-7-28 are heavy duty units which can deliver up to 27 hp at 1000 rpm.
For your info. deuces and 5 tons share the same rear output shaft housing, 7/8” shaft and inner parts on their PTOs. The 5 ton version is mounted on the passenger side and has a different input gear mesh and longer front output shaft but most other parts are interchangeable and housings are equally strong .
Hope this helps.
Gerhard
