36-3580 HD HEADLIGHT HARNESS Questions M1009
topgun217
The Northern Border of Ohio
Just got my LMC relay installed. For some reason the passenger side headlight is dim, extremely dim. Did I do something wrong with the install? I do have a halogen bulb on the driverside and a GE bulb in the passenger side, could that be the problem?
llong66
kokomo, In
topgun217, when you say you have a halogen on one GE on the other, are you referring to the maker of the bulb or the type of bulb? If they are different types, I bet you will see the problem follow the bulb if you follow Warthogs suggestion.
