4 speed trans conversion
racingjoe66
Lime Springs, Iowa
Hi guys, I purchased a 1986 HMMWV M998 A0. It has a rebuilt detuned 6.5 in it already and still has the 3 speed trans. I am wanting to update it to a 4 speed trans and leaning towards a mechanical non computerized 4 speed. I was wondering if anyone has done this and has any pointers for me. I am planning on having a local guy go through the trans for me and put a kit in it as I want it built for towing as I plan to put a receiver on the back so I can pull a small trailer with it and also pull m 1967 Jeep Kaiser M715 behind it when mudding and also my boats from time to time and also to gain some cruising speed.
any and all help would be greatly appreciated.
thanks
parklandtrans
Roy, wa
If you are going with the 4L80E trans, which is the only 4spd overdrive trans for the HMMWV.....You will require the stand-alone computer brain box. This replaces your conventional computer in your POV. Very simple plug and play set up...doesn't get any easier then that my friend. You will also need the shifter Assy with the "Park" position, specially for the Overdrive transmission. Any other questions feel free to PM me and I will answer as soon as possible.
Parklandtrans/ Bob
Retiredwarhorses
4,171
Brentwood, Calif
Thanks Bob. I was told the cross member needed to be moved back some also for the 4L80E and possibly a different transfer case? Will send you a pm
Yes and yes....plus several other things. I find it funny how folks say it's just as easy as 1,2,3...
the crossmember is not moved back, it's replaced. The 242 tcase mates to the 4L80E, your also going to need drive shafts too. To be fair...I don't do after market conversions....I do factory OEM work at my shop.
I am sure these non factory conversions are cheaper then an OEM conversion....
racingjoe66
Lime Springs, Iowa
Which crossmember is it replaced with? And I didn't think it was as easy as 1 2 3, from everything I have been reading up on it. As for the driveshafts, are there some that work or do some need to be made? I am thinking this will be a conversion I want to do this winter, so any help is great
Retiredwarhorses
4,171
Brentwood, Calif
sorry Joe, I didn't mean you thought it was as easy as 1 2 3....this thread topic is not new.
99nouns
17
Ocala, FL
Can you guys keep your conversations on here so we all can learn please, unless you planing to patent your findings...
Thank you and carry on...
Action
1,557
East Tennessee
The crossmember is replaced with the one made for the 4l80e. Propshafts do not need to be made. You just buy the correct ones.
parklandtrans
Roy, wa
Warhorse,
thank you for the correction on the 4L80E swap for Joe...if you've never done the conversion..it will not be as easy as "1,2,3"...however, after the first one is done successfully you will feel like you can do anything on the HMMWV...I think a lot of the other folks would agree..!!! Joe, the real key is to obtain as much info as possible prior to starting project..information is power and is the best tool in your toolbox..!! Bob
racingjoe66
Lime Springs, Iowa
I will do a lot of research and part searching before I proceed with this swap this winter. Are there any upgrade kits out there for the trans or torque converter made more for pulling heavy items? If anyone can copy & paste links to some good write ups on this swap, I would greatly appreciate it.
Thanks again Bob & Warhorse & Action!
Lionel
24
Baltimore/ MD
"the real key is to obtain as much info as possible prior to starting project..information is power and is the best tool in your toolbox"
Information and about $6,000 + in parts.
Action
1,557
East Tennessee
It is better than the 218 that comes with the old 3-speed. The 242 has two cooling line ports on the front of it. A revised version will have a blue band on one or both of those tubes. That is the preferred one to find. The non-banded one had some issues with leaking the cooling fluid into the transfer case. So the trans would run low and the t/c would get high.
