Thanks, will look it up and try it. Do you know if once the float swells, does it stay swollen, when dry, or does it shrink back to original size when the gas evaporates?i have a post on here on how and what to use to coat these floats. the carb is the same as the 1ao8 and 2ao16 the float is made of foam and swells when used in ethonol gas . once you coat the float you should run all ethonol gas out by shutting off the fuel and let run till it quits just to be safe. i have coated 8 of these floats and havent had a problem since.i think my post was titled 1ao8/2ao16 float fix. hope this helps
I had a guys card but lost it. I need one for mine also, I will make a couple of calls and get his name and number. The carbs are out there and price is not bad.Is there a known alt source for carbs other than saturn?
Thanks! Guel pumps for $20-30 are gravy to find but $70-75+ for a carb. I always figured mule carbs would be the higher of the 2. Ive got a few of those that i got for $40 shipped.I had a guys card but lost it. I need one for mine also, I will make a couple of calls and get his name and number. The carbs are out there and price is not bad.
Rick
