panzerwillie
- 136
- 43
- miami florida
Well i'm almost done with the 4l80E trany, redid the valve body to a full manual shift, it uses a vacum module of a 400 for increasing line pressure so i will be instaling a vacum pump set up like 1009, also got a deep pan need to modified a line inside so it sits flush is out of a later 99 or newer 4l80E i belive, will try this for a while and if i do not like it will go back to a normal valvebody with a stand along TCM, will post pictures of the swap from the 3l80 to the 4l80E
