davo727
- 2
- 18
- Cleveland, TX , Spring , TX
You said dichotomy.... thats too big of a word for around here.
Oops how many days did that set you back?Here is one from my phone. Heading back up tonight to make a relocation bracket for the coolant reservoir, tie in the aftercooler, and run the intake and exhaust pipes. Note to all - when you add the fuel line tap to the rear of the head, make sure the pressure and return lines are in the right spot. Motor won't crank if you don't........
