162tcat
- 44
- 28
- Washington
New or take offs?
The door frames are a great idea I think but man what a job to remove them and pretty much wrecks the Pete cab doing so.I later found out you can buy them for $600.00 each new.I parted out the Pete so the door frames and doors ended up being free.The door frame??? looks like you have a good plan on that... some finished doors off something else?
As for wipers I like the M35A3 kits simple to modify to fit and should be able to get parts for a good long while, it uses the humvee motor.Anyone have a good idea what seats would be nice in here.Thinking I want air ride.Also what would be a good aux heater system or would a combo ac/heat system be available. One last question what would be a good wiper system to install preferably 24v.
That's funny actually its none of those things nor is it an old style key hole for the door lock. It's the marker light hole.I scored some OEM marker lights.Hey Carl - what's with the banjo hole in the cab cill?... or did I miss something in an earlier post....
Was it for lifting the cab into place?
Securing antiglare scrim over windscreen?
For friends to chain door when you are sleeping inside?
