So I received my torque multiplier wrench this week and tried it out yesterday. I didn't have time to change the tire but I did want to see if I could break the lug nut loose with this new toy.
Here is a quick review... I may submit a more detailed review once I change the tire with it...
1) I ordered the unit on a Sunday, it shipped on Monday, and I received it on Wednesday.
2) Before I bought the tool, I was concerned about the interference between the tool body and the rear hub pushing the tool sideways during use. The tool body does indeed touch the hub but not enough to cause major problems. The tool looks mostly perpendicular to the lug nuts when viewed straight on. The tool body is 2.820" in diameter where it touches the hub. I did some math using a worst case diameter of the hub, 8.75" a bolt pattern diameter, 11.25", and came up with .16" interference, or a little over 1/8". A person using an impact wrench probably doesn't hold it that straight anyway.
3) It takes a little work to get the tool positioned over each lug nut and into the correct position. At first, I could only get it in position to react against the hub but I soon figured out how to get it to fit against an adjacent lug nut.
4) I had to lean on the the crank a little to get the nuts to move but they come loose with much less effort than using a breaker bar.
5) Overall, this is a great tool and I can't believe that I've never heard of them before now.
View attachment 550310 View attachment 550311 View attachment 550312
