jatonka
- 90
- 48
- Ephratah, New York
First, I did a search.
Can anyone give me a civilian part number for the 5 ton PTO output seal on an M39 deries which should also be the 800 series PTO for the forward facing out put shaft for the winch driveshaft?
I bent my drive shaft Saturday pulling out a pickup built on 5 ton axles running 60 inch rice and cane tires in a heck of a mud bog. I have a shaft but need to replace the seal in the PTO.
As a matter of interest, I was pulling in high retrieve because I was having trouble finding loe speed and it was a terrible hard pull, all my fault on bending the driveshaft. The shear pin is aluminum and it did not break, only has a small bend in it. I'm pretty sure it is a military pin but there is a chance it might be one of the ones I built. I keep the RPMs around 1000 when I do recoveries .
The existing seal is a Trostel 256-148-8
Thank you, JT
Thank you, JT
