ramdough
- 1,730
- 113
- Austin, Texas
That is a great quote!
Any more pictures of this truck
I don't really understand what you mean Suprman. The axle is not going to move when I install the 16r20's, so wouldn't the center of the wheel be in the same relation with the frame and cab when I install the larger tire? So my measurement (at about 26.5") is representative of where the 53" tire will sit inside the front wheel well.
CoachGeo, if my math is right. the 3.07 is a 127% jump from 3.90 ratio. If that was applied to the tire height, it would be the same as going from the 46" tire to a 58.42" tire. So the 53" seems to be somewhere in the middle, certainly will add more rolling weight than gears.
Running 16.00s on mine and love themdoes anyone used 16x20 on the lmtv 1078 4x4 instead of the 395s? Thanks Rubens
Hello Do you have any issues with the front tires touching anything?Running 16.00s on mine and love them
Not any more but I moved steps up so the top of them is level with the bumper and trimmed the front fenders and cut the cab bag mounts you could get away with doing less if you aren't going to off road it but mine gets usedHello Do you have any issues with the front tires touching anything?
thank you !Not any more but I moved steps up so the top of them is level with the bumper and trimmed the front fenders and cut the cab bag mounts you could get away with doing less if you aren't going to off road it but mine gets used
