67_C-30
- 3
- 0
- Sweet Home Alabama!
Besides the slightly different injector angle, the biggest difference is the size of the ports in the precups. The 6.2 precups have small, round d-shaped ports and the 6.5 have wider, bigger oI haven't seen the exact post you referenced, but similar information is available in another thread on that forum that I have been reading.
http://www.dieselbombers.com/6-2l-6-5l-performance/68582-6-2-performance.html
The fuel mileage is another reason I am interested in the 6.2L. I am more interested in higher torque than higher horsepower, but obviously, increasing the output of one will increase the other as well. Some of the structural issues with the block (provided we are starting with a good block, meaning no cracks, etc.) can be improved by having the block cryogenically processed which will "correct" some of the molecular imperfections by equalizing their "layout" in the casting.
As for the crank, I have read that the crankshaft is a weak point, but mostly from a collateral damage perspective due to a spontaneously failing harmonic balancer and/or weak main caps. This leads to more questions, of course. The issues with the main caps can only be addressed so much without changing the block casting itself (such as with the P400 6500 block). But what about the crankshaft? Are their forged cranks available for the 6.2? Where can I go to find the specs on the main and rod journals? At one point, I had found a company that could custom grind just about any crank you could come up with, I remember having a discussion with them about a custom ground crank shaft for a high HP 4.3L GM V-6 back in 2004. The pricing wasn't to extreme, but it wasn't cheap either. I also know that I can get custom ground cranks for my Hudson and Terraplane straight 6's and straight 8's... this leads me to believe that the 6.2 should also have something out there to take care of a weak crank shaft.
Also, with the recomendations that the harmonic balancer on a 6.2/6.5 be changed religiously every 100k miles, one would presume that there is a performance upgrade for these as well. And thinking about my Hudsons, their blocks are balanced and blueprinted from the factory (and their blocks are actually a chrome-moly type variant)... how well would balancing and blueprinting the 6.2 work out for us? The article I posted above about the race engine implies that this was done (as well as other fairly extreme measures) and that the 6.2 connecting rods were used for strength reasons.
And I am still looking for the exact differences between the 6.5 and the 6.2 heads. I have read that putting the 6.5 heads on a 6.2 makes a screaming bandit... for a short while, until the EGT's get to high and that's all she wrote. But if the valves on the 6.2 are larger than the 6.5, all I can think of is that the intake/exhaust runners are different between them and/or the precombustion chambers are different. But which one is the cause of the massive gains from putting the 6.5 heads on the 6.2, and what can we do to keep this combination from grenading the engine shortly after the build?
blong shaped ports. The diamond precups used in 6.5 turbo engines will make more power than 6.2 precups, but at the expense of fuel economy.
The first is a 6.2 precup and the second is a 6.5 turbo head.
