6.2L "training" video
Mogman
10,204
Papalote, TX
This is a hoot, a 1981 6.2L training video, actually more like a "familiarization" video, I remember these coming out, once a week we would sit and watch these, VHS was just really taking off about then, before that we would need a projector.
Interesting about the timing marks, we treated the 5.7L the same way, they were run in on a dyno at the factory and would be "optimized" before installation.
Only we made matching marks with a small chisel as the paint would have likely be removed by the re-builder, back then every town had a injection shop.
I worked for a Cadillac/Olds/GMC dealer, man I can still remember the verbal fights in the service managers office when a relatively new Cadillac/Olds owner was told the IP was not covered by warranty because of rust in the IP, after all GM did not put the water in the fuel.
When the guy says "other diesel engines" he is talking about the 5.7L series of engines which were patterned after the 5.7L Oldsmobile engine.
Many of these HD diesel blocks were converted back to gas with some machine work and some special main bearings for the gas crankshaft, would pump out mucho HP on gas!!
Mogman
10,204
Papalote, TX
When he talks about SAE/USS VS Metric, some things on the 6.2L are USS, bell housing bolts (the TH400 was a SAE/USS transmission), IIRC the fuel pump bolts were USS, probably others also.
Mogman
10,204
Papalote, TX
Imagine how short sided the design is that you have to remove the fuel lines from the secondary fuel filter to change a spin on filter, the last line of defense for the IP, increasing the exposure to foreign particles...
