detroitmuscle1986
- 0
- 0
- bar harbor, ME
So, I have a complete running 98 gmc 3500 with a 6.5/4l80e combo. I want to swap that combo into my 1028A1. From what I have read I believe if I machine the adaptor between the tranny and TC I can make the 4l80 fit the np205. Where I get lost is with the electronics part of the swap. I will keep the stock electronics on the 6.5 and use what I can off of the donor truck. I wont even need to separate the engine and transmission. Will I need to make a custom VSS to work on the 205 or is there an aftermarket conversion? Can I use the electronic throttle position sensor from the donor truck or will I need to use this http://www.tciauto.com/tc/4l60e-4l80e-remote-tps-w-mounthtml/? What other electronics will I need to use or buy when I make the swap? My overall goal is to get a little more power from the 6.5td and get the overdrive. If it comes down to it I can always just put the 6.5 turbo on the 6.2. Any info will be of great help!
