erasedhammer
- 58
- 28
- Maryland
I'm starting this thread so I can get a lot of answers for my numerous questions now and ones that will pop up as I go through the swap.
I am currently in the process of getting a GEP 6.5 TD, it runs, but other than that I don't have info on it, yet. I have acquired the Doghouse recently.
What I currently have: 6.2 mated with 4l80e and 242. I have the 6.5 eng harness and a2 body harness already.
My Q's:
1. Anyone have a generic list of what is needed to throw a turbo in place of a 6.2?
2. What sort of body modification needs to be done (and where) to make the turbo doghouse fit?
3. Do I need a body lift to snug the engine in, or can I get away with not?
4. In the case where the engine I'm getting doesn't have the accessories (alt, power steering, fan, serpentine, ect.), anyone have a list of what can be reused from the 6.2? I imagine since I already have my 200 amp alt, if I get an engine without an alt I can change it over and have no issues.
5. I'm looking to replace the doghouse insulation, anyone know where I can get some? I want to get the reflective one, not the black rubber insulation I see on ebay.
Where does one get what looks like rivets that hold the insulation on? They appear to have a pop rivet head on them, how exactly are they installed?
6. Can I used my old radiator stack with the turbo engine? Any hose issues there?
7. What's a good source for a rubber intake tube, most likely my engine won't have one hanging off it. Can part of the rubber na intake be reused (like the 1st section coming off the filter?).
8. Saw Augis post about his conversion with the new engine and 4l80, he highly recommended the engine hoist bar, any source on that? ebay?
9. For the swap itself, I'll take the hood and radiator stack off of course. I have a friend with an engine hoist. Whats the easiest way to go about taking the engine out? Strip it then remove it? Just take the whole thing out all together? I'm trying to take the most efficient route here, not the necessarily the easiest. Obviously I'll be leaving the transmission in, since I already got the 4l80.
10. I'll probably be going over and through the engine when I get it. Anyone have suggestions on what I should check at the minimum?
11. For those who have done the 6.2 - 6.5td swap, any tips and tricks I should be aware of ?
I'll probably post my own reply to the thread if I ever have more questions (mostly likely I will)
Thanks
My Q's:
Thanks
