6.5L Drive Shaft NSN
Odakrem
North Wale, PA
Hello all!
Im looking for th NSN for the front and rear drive shafts. I finally got my 6.5 swapped in with the new body harness and TCM and the works, but I'm confused on which NSN is the right one for the 6.5 drive shafts.
My 6.2l drive shafts have no markings so I can't use the process of elimination to make sure I'm looking for the right driveshaft and NSN number.
Any and all help would be greatly appreciated!
Retiredwarhorses
4,143
Brentwood, Calif
You will need:
5937525
YOKE, AXLE (W/SLINGER) {12.1 GVW}
2​
$101.63
$203.26​
5579450
SPACER, PINION (CRUSH)
2​
$2.38
$4.76​
12469311
STRAP, BEARING (12.1 GVW)
4​
$1.45
$5.80​
12469283
BOLT, HEX FLANGE (BEARING STRAP) {12.1 GVW}
8​
$1.45
$11.60​
12339050
U-BOLT, TRANSFER CASE
2​
$5.52
$11.04​
12469284
SHAFT, PROPELLER (REAR) (12.1 GVW) ~
1​
$350.00
$350.00​
12447114
SHAFT, PROPELLER (INTERMEDIATE)
1​
$400.00
$400.00​
01-423-5120
SHAFT, PROPELLER (FRONT) {W/BEARING}
1​
$300.00
$300.00​
[FONT=verdana, sans-serif][/FONT]
