Dock Rocker
- 72
- 28
- Jackson ms
We brought this one back from the dead
Looking forward to following your build. I am getting ready to do a 700r4 with a 241C. Everyone keeps saying it won’t hold up but I have personally seen them handle 750hp rock crawlers and 1000hp drag cars. Most of them were only mildly built.Thanks guys for all your help. I'm definitely gonna move forward with the 700R4. I'll do a write up for anyone looking to do the same.
Horsepower isn’t what kills transmissions typically, it’s heat. Get a well built 700r4 with a beast sun shell and upgraded clutches and the biggest cooler you can find. The cooler adds capacity (more fluid) and cools faster. If you do those things you will be fine.Agree with you there. I've seen several people say the 700r4 won't handle it.............which leaves me scratching my head because its a 165hp motor........... Like you, I've seen them in several built rigs, and they handle it just fine.
I’d say TORQUE & heat kill them.Horsepower isn’t what kills transmissions typically, it’s heat. Get a well built 700r4 with a beast sun shell and upgraded clutches and the biggest cooler you can find. The cooler adds capacity (more fluid) and cools faster. If you do those things you will be fine.
Replace your flex plate with the correct one for a 700r4.Ran into a snag on my conversion. The flexplate on mine is a six bolt pattern and it's not lining up with the three bolt hole on the converter. Any suggestions? Thanks.
I went to Napa and they gave me BK 600541. Based on the research I've done, I believe I need BK 600542. I hope that's right because my mechanic is going to kill me if it isn't. It's holding up his lift. I know this sounds silly but I printed both pic's out and lined them up in the light and the holes are in different places. Fingers crossed.Replace your flex plate with the correct one for a 700r4.
The adapter used to mate the different spline count 218 to the 700r Necessitates the different driveshaft length.The rear shaft had to be shortened? Thought the 700r4 was close to a bolt in. You using a 218 or 242 transfer case?
Matt
Several companies make adaptors.700r4 is 27 spline, turbo 400 is 32 spline.
How are you addressing that issue ?
It depends on what your meaning of "better" is. Yes as far as a more robust trans but no as far as cost and if you want to stay away from electronics and have a dumb trans. I prefer dumb and I'm only looking for grocery getter not offroading really.Both my cars run LT1 against 460LE. Is not that the same and/or better than 700R?
There is PDF attached. If you see just a black boxes just click on it and it will work.
