- 6,669
- 9,304
- 113
- Papalote, TX
I have this question too.
If the input gear (NP21 is changed to a 27 spline then the stock NP241/700R4 transmission/transfer case adapter and original 27 spline 700R4 output shaft should work yes?
I have not been able to find a 32 spline output shaft but only the $500 Advanced Adapters kit for direct adaptation to the 32 spline NP218,
27 spline NP208 input gears are plentiful (same gear as the NP21
