MAdams
- 139
- 43
- San Dimas, CA
It was raining the other day and I was home sick cruising the internet. I looked for a better spin on fuel filter for the secondary filter mounted on the engine because its only a 14 micron. I couldn't find any info so I searched the wix filter website for any close matches.
I JUST changed my stock primary canister filter so I'd rather not replace it with a spin on right now plus that still leaves a secondary 14 micron filter.
The secondary filter is a wix 33472 which is a 14 micron filter that flows 8-10 GPM 16x1.5mm thread and has a gasket size is 2.37ID and 2.74OD
The wix 33124 is a 6 micron with similar dimensions as the 33472 but it only flows 6-8 GPM. It also doesn't have a bottom water drain.
The wix site doesn't get into efficiency, delta pressure and filter capacities but it looks like this filter will fit and is a upgrade in micron filtering. Anyone tried this or any other filter?
Again, I know replacing the factory primary canister filter with a dual spin on is the best solution, but that's not an option right now.
