8.3L Hydraulic Pump Add
74M35A2
339
Livonia, MI
For any wanting to add hydraulics to their 8.3L vehicle, I wanted to illustrate another way. You can use a belt clutch hydraulic pump on the factory serpentine drive. Simply mount the pump in place of the A/C compressor of the kit. Pump has fittings on sides and rear, can use either or combo. Can actuate anytime, regardless of driving, stuck, neutral or drive, etc.....
74M35A2
339
Livonia, MI
Looks like a neatly done install. What is flow of your pump and what are you driving with it?
Thanks. I can’t say what I’m using them for because I’ve applied for a patent on it, but I can run the model numbers through Munice’s website and publish their specs. You can get 24v and V belt clutches as well.
74M35A2
339
Livonia, MI
Here is the page, up to 11GPM @ 1,000rpm. So just a bit under the 925 max rating of 25GPM @ 1800rpm, but you can spin this one even faster and out-flow it if you need to.
