willys2point3
- 26
- 13
- Roxboro, NC
Hi, I need to address a couple of minor leaks on my 802A and I could use a little help:
1) Fuel banjo fitting weeps diesel where it attaches into the small "secondary" filter. It has no copper washers or other sealing mechanism that I can notice. Are there washers that should be on either side of the banjo fitting? What size? .
2) Injection pump on the block is seeping a little engine oil around its base. The "fork" that holds it down is as tight as I dare tighten it, but to no avail. Is there a seal/washer of any sort under that may need replacing? If not, suggestions for resolving the leak? I could just try some permatex, but I'd prefer to fix it right.
