Trashistreasure
- 10
- 3
Hi all to start with this site is an irreplaceable wealth of knowledge though I am a new member/poster many Google searches have led me to previous threads leading to fixes with problems with various machines.
now to the point I’m involved with and MEP802 The problem is 2 to 3 hours into a normal run shift The machine stopped putting power out but Bogged down and is reading overloaded on the load meter even without main contactor engaged to AC output terminals. The machine will start engine runs fine field does not energize until master switch is rotated to flash the field at this point main contacter is not engaged to ac output terminals engine bogs down load meter pegs to overload reading. The machine will start engine runs fine field does not energize until master switch is turned to flash the field at this point main contact her is not engaged to ac output terminals engine bogs down load meter pegs to overload reading. I have tried setting voltage selector knob to different settings starting and re-trying with the same results. I did see some sparks coming out of the generator and I’m assuming something has shorted out and it’s pretty much a write off but it’s always nice to have more knowledgeable people confirm my uneducated thoughts. My mentality is I know nothing until someone who does know something has taught me. I try to do my research before tearing into shit.
