Hi all... I am a newbie, so don't bite my head off if I've made a mistake and posted wrong... PLEZ!
I just purchased 2 MEP-802A gensets BECAUSE I was under the impression from reading the manuals that they could be paralleled using the proper cable. Well... the gensets worked PEREFECTLY once I found the proper filters and batteries; however, I found no parallel cable with either generator NOR did I find the "Unit-Parallel" switch that is required to operate them in parallel. I contacted the support department at Technology Research Corp (the company that made all the controls) and Doug couldn't tell me if the 802A has that ability. He suggested I contact this forum as you are the 'experts' when it comes to using these things... he just knows the controls. And BTW: because these units are 'current' military his company CANNOT supply any of the controls to us as end users. Luckily I don't require any parts as these started up and ran like they had eyeballs. And SO QUIET... totally amazing! Back to my issue... am I missing something here OR are the manuals incorrect? Can these be operated in parallel?? (without a PH D in generators)
Thanks in advance for your help.
