justacitizen
- 40
- 28
- oklahoma
on an 802A were is normal for the battery charge needle with fully charged and low battery???
That should only have to be done once to calibrate the meter reading. Its not something that needs to be done routinely.I set mine to 0 when off and when its been running for a bit about 5a or a little above the 0 mark is normal.
That flat slot in the gauge face is the adjustment.
If your batteries are low, it would help to charge them first before putting all that charging load on the alternator. The alternator should "top off" charged batteries in fairly short order after starting and your meter should return to 0 as proper indication.Thanks. it appears mine is working properly but i will continue to monitor. my gauge pretty much runs full over but not out of the green area,i think the battery are low though. it appears that on my new 4000 hour unit that a battery has exploded sometime in the past and i suspect the VR might not be functioning properly.
