When I assemble an engine I like to coat the bearings and piston skirts with assembly lube. Gives a little extra protection at start up. I usually just wipe a thin coat of oil on the rings. No assembly lube on those.
I have used this method to put bearings, gears and such things on pumps. Normally they go right on without much trouble.
Worked like a charm. Got the oven to 460 and let the gear sit in the oven for about 30 minutes to heat up. Put it on the crankshaft and it slid a bit into place and I used a large socket (for the Motor Home) and tapped it into place. Just a tiny tap here and there.We use a bearing heater here at work. After you get it to the proper degree it will slid on by hand. If you start to put it on and it sticks knock it back off and heat more.
I always use an assembly lube on my rebuilds. I can not tell you how many engines that I have heard about being destroyed by a dry start up. Yep, that metal to metal with no lube is just screeching to be released.When I assemble an engine I like to coat the bearings and piston skirts with assembly lube. Gives a little extra protection at start up. I usually just wipe a thin coat of oil on the rings. No assembly lube on those.
Cam bearings often have to be align bored/honed after install. Not an at home task.Got the pistons installed with no issues except the rings. I noticed that if you are not very careful when using the ring compressor that you can spin the ring out of position. Have to be very careful about that or else you can wind up with on ring split sitting right on top of another one.
The camshaft did not want to go inside the camshaft bearing. The split in the bearing was at the top but was completely closed and sure enough, it made the bearing .001in smaller than the diameter of the camshaft journals. PITA to get out but I used the old bearing (from the last rebuild 15.5 hours ago) as it was just as new and in specs as required by the TM. I hated to do it but if I did not, I would be down for another week.
Tried installing a new relief valve in the oil pump that I got from HQ Motors just to find out that it would not thread into the oil pump. Spent 1/2 hour trying to figure out what the issue was. The old one went in just fine, the spare I got went in just fine, but the new one from HQ would not thread into the pump.
So bad sized bearing and a problem with the new relief valve. Neither a show stopper.
Bottom half is put together so tomorrow it will be the top half.
Well, I finally have the engine put back together. Spent a week on vacation so I got delayed. I also had to wait on parts from the seller which for some reason took a month to get. It is married to the generator and in the cabinet. I will finish doing the install today and will try to fire it up after filters and fluids.Cam bearings often have to be align bored/honed after install. Not an at home task.
A man, or woman's word should be their bond. And when it isn't, then as long as I don't lie about them, that's the way it is. Getting to old for this world I guess.
