- 359
- 26
- 28
- Burdett NY
Is there a constant 24 volt draw on the 803a battery's???
Do you mean when off?
Do a search, but the only real potential for a draw is thru the alternator. I think it is a bad diode. You should remove the negative battery cable and hook your DVM up to see what the actual amperage draw is.
You shouldn't have any draw when off. I only start my personal units every 6 months and never have an issue. As CapePrep stated, the alternator is usually the root cause of excessive battery drain due to internal diode shorting. You can rebuild them for less than $40 and its simple to do.
You need to disconnect the positive cable and leave the negative on. Measure the resistance from positive cable(not battery terminal) to ground, then reverse the leads and see if that resistance changes.Have negative disconnected read 11.9 volts amps settle down to .06-.05??
[/QUOTE]Made no difference what was or was not hooked up! I might of made mistake # 1 bought inexpensive (cheap) Wally World batteries!!!
QUOTE=RJM27;2109430]Have negative disconnected read 11.9 volts amps settle down to .06-.05??
A shorted diode in the alternator will read a low resistance in both directions. A good diode/s will read high in one direction and low in the other.
Be sure panel lights are off and disconnect charging device too.
