- 2,037
- 221
- 63
- North West Arkansas
Spent Friday in Hooks TX, picked up my compressor, medical chest and 5Ton Winch, had to wait an hour since someone came in early and got my appointment, no problem, I'm picking up my 5Ton! Traveled the 4 miles to Lone Star to pick up my long awaited M818 (6000 miles since rebuild), check all fluids hooked up the 4 batteries, made sure the fuel shutoff was not out, piston was in, she turned over great about the first minute or two had good smoke but would not crank! Primed each time, preheater light came on quickly. Turned over good and steady no more smoke, checked to make sure fuel cutoff was in, again. Both tanks are almost full, I added octane booster and five gallons of new fuel very little smoke no run. Sprayed a little WD 40 into breather would run for a few strokes. GL guy was ready to go(less that 2 hours), didn't have time to blow out fuel lines.
I am going back Monday week, I am going to blow out the fuel lines from tank to Filter(fuel in filter looked great no water). GL guy said this was the first one out of the 40 on the lot that did not start, am I lucky or what. When it smoked good for a min. or so when I first started does the IP have a small reserve the engine could have been running off? I had high hopes when it was truning over good and I had good smoke but that only lasted about 1-2 mins. of it truning over then almost no smoke after that, unless WD 40 was being sprayed? Its a 6 hour drive to test starting theories so I need some good advice before I get there!!!!
Thanks,
James G
Thanks,
James G
