86cucvky
- 0
- 0
- lebanon,ky
I have a 3 speed auto in my 86 cucv blazer with a 6.2 diesel....looking to swap the tranny out with a 4 speed manual transmission...what will work
Hmm, I've been thinking over the turbo too. Read through the Diesel Pages vol 1, and keeping an eye open for a Banks unit and also the GM unit that was discussed in another thread here.You won't have the power. I added a turbo and it will run most hills.
My apologies if this is a dumb question...but the transmission is not my area of expertise. Here it is....if one installs the NV4500 does that allow the 6.2 to hold a highway speed on some of those longer, higher hills or allow it to drop down into a better gear to hold say 55 or 60 on those long hills?
I'm not after a 70 mph rig, just one that isn't 45 or worse on those hills. So if a transmission is the answer...then I'm willing to learn!
To further expand on this: the larger the tire the slower it will be off the line, but the higher the top end speed (and the lower the rpms). Bigger tires will also hurt your hill climbing ability a little bit due to the lower rpms. Small tire= quicker off the line, lower top speed/higher rpms.IIRC you've got 308 gears in your truck why not step up just a little in tire size? Just plan it out when you need them and go a little bigger, just make sure you look up a tire rpm calculater so you don't over do it.
