gvschafer
- 0
- 1
- Monroeville, OH
Have been driving the recently aquired 925A2 quite a bit lately, and have been noticing a problem. When trans is shifted fron neutral to drive (1-5) the trans seems to "drop" in so hard that it stalls the engine of the truck. When I first got truck a few weeks ago there was no problem. Then when it first happened it was only when truck / trans was cold, right after start up, then would go away. Now, even though the truck will drive when trans is warmed up, there is still a noticable shudder and engine hesitation when shifted into drive (almost stalls). All seems to function 100% in reverse, and once truck is in drive there is no other problem. It drives and shifts fine. Only when transitioning from neutral to drive is there a problem. My question for you more experienced members is has anyone had this problem before? Any suggestion as the to cause or cure?
