A question from a noob
erich92
Moreno Valley, CA
My father in law acquired a 1990 M923A2 with a Cumming 8.3 and an Allison transmission as a family project. It's in running order, but he was told that since it was a base vehicle, the speed was governed to 25mph. Does anyone know where or how to adjust the governor in order to allow this beast to run at highway speeds? Any help would be appreciated.
5tonman1971
Lima ohio
It could be limited on the screw under neath the fuel pedal or could be limited at the injection pump. Check all the linkage and shat not.
But ur there is also a TM SECTION. That will tell you everything you need to know and how to do it properly.
EMD567
Driver for the Ga Mafia
47
Aiken SC
That would be the first thing I checked- Is the transfer case in high range.
doghead
4 Star General /Moderator
1,179
NY
Never heard of that before.
Like the others said, try shifting the T case into high.
doghead
1,179
NY
Also, read the -10 level TM.
2,464
Not to say I'm doubting the prior owners word but I was around all kinds of Armed Forces bases for a very long time (still am actually) and I've never heard of a "base truck" or one being governed to 25MPH.
Again...I'm not saying it's wrong...I just never heard of it.:roll:
I'm going with the T-Case in low range as well.
Are you sure the trans is shifting up thru all gears?
RustyM923
California
The placard on the dash shows 26mph max in low range, and 63mph max in high. Perhaps it's locked in low.
If you can go about 15 in 1st gear, you're in high range. If it's about 7, then you're locked in low.
