Guys I own an M916 . I want to connect a 12V two outlet accessory
outlet to power phones, GPS, etc. Here is a picture of the circuit
breaker box and what I "think" is a "Buss bar" or a distribution
type of block below the circuit breakers in the truck. HERE is
a picture of the fused 12V two outlet accessory outlet.
You can see the red and black wires connected to the "buss bar" that are turned into a curly cue,
those or the wires that feed my 12V Accessory box.
I checked the voltage w/ the engine running, it was 13.xx if I remember right.
I grounded it right to the dash as you see. Everything worked fine, the lighted rocker
switches on the accessory box lite up and my Streamlight Flashlight charger light came
on, all good. OK DONE, but.................
...I drove to an AMVETS swap meet and on the way my GPS shut off, I looked
over and saw the lighted rocker switch was not lit up! Then it was lit up,
then it was not lit up again! ???
Any help gents?
CLICK HERE to see a Schematic and CLICK HERE to see the dash harness.
Any help gents?
