with what speedometer cable ratio? I believe and probably wrong, but its a 1:187 for 11.00x20 tires, and 1:200 for 9.00x20 tires.
depending on that and actual overall diameter of the tire you can range from as little as a 3% to as much as a 12%(I think, math might be off) difference.
I have actually used a permanet marker and marked 30, 40, 55 and 65 on trucks that have incorrectly reading speedos(most due to tire sizes)- takes two seconds to find one of the speed traps, or follow a friend using a car with an accurate speedo, then mark your speedo after some steady driving.
If you wish to get real crafty, you can actually make a new face and install it-no clue how hard it would be to pull apart a military speedo though
