adding a winch to a non-winch truck
BFR
Rocket Surgeon
2,330
42
North Georgia
Thought I would document adding a winch to my truck.
I pulled the winch, brackets, bumper and PTO shaft as a unit. Then I seperated and sandblasted the peices (I only presure washed the winch housing).
End of weekend 1
BFR
Rocket Surgeon
2,330
42
North Georgia
weekend II
Coated the peices w/ oshpo during the week then primed w/ rustoleum.
removed the recipient trucks bumper and cleaned up the ends of the frame rails, again primed w/ rustoleum. Then I started putting it all together w/ new grade 8 hardware ( :shock: there are over 40 bolts). I decided to mount a second set of lift ring mounts under the bumper
bigkaiser
Skagit Valley, WA
Joel,
I went through the same steps recently and all went fairly smooth until I tried to set the winch between the frame rails. The rails were 1/4" to narrow for the winch to fit. I had to loosen all 40 of those bolts and unbolt the bumper to try and squeeze the winch in. Then when the winch finally fit the bumper holes no longer lined up and were now to far apart. Now the ends of the frame had to be forced together.. talk about fun...I hope mine was the exception. Did you go the route of finding longer bolts in order to mount the extra shackle mounts or just bolt them top and bottom..by the way i seem to recall all of that grade 8 hardware costs about 80 -100 bucks for those that have not been there yet.
Good Luck, Don
BFR
Rocket Surgeon
2,330
42
North Georgia
I wouldn't be suprised if I end up loosening/retightening when the winch goes in aua . I did get longer hardware for the lift ring mounts. As a mater of fact the two thin bolts will need to be cut in order to get a shackle pin in them, but that will wat until last. the new hardware was spendy but 54 years and my removing it absolutely destroyed the old stuff.
1,808
Coming along nicely Joel. Did you use the original bumper from the 185 or the bumper from LeRoi? I've found that if the bumper is the least bit tweaked, alignment is a PITA. I got real lazy here a few years back. When I removed the winch from the M35A2 and installed it on the M275A2, I unbolted the winch, extensions, bumper as a unit and swapped the whole thing with the factory bumper from the 275. Had its moments but I think I did save time.
** Word of warning, get a piece of Luan or Masonite and cut it the size of the radiator core. Intall that against the radiator while dropping the winch in there. One little tweak with the prybar and the winch can damage your radiator.
BFR
Rocket Surgeon
2,330
42
North Georgia
the only parts from the 185 are the lift ring mounts (the ones on top). Any one know where I can get the bolts that actually go into the winch?
Edit:
I also used the handles that go into the frame from the M185A3
1,808
The shouldered mounting bolts? If so, good luck. There are 2 different lengths. What happened to yours?
bigkaiser
Skagit Valley, WA
Joel,
I finally found the special shouldered bolts from Sam Winer in Ohio 330-628-0948 (Robert Zetzer) I think he charged me about 25 bucks for a set (6 long / 6 short) I have a drawing with dimensions if you need it....pm me
Don
BFR
Rocket Surgeon
2,330
42
North Georgia
most of the bolts are ok, but the two lower ones (don't remember if they were from the long or short side) on one side have damaged heads.
BFR
Rocket Surgeon
2,330
42
North Georgia
weekend III
Today I got the winch in & cut the bolts that were a little long. I pulled the drum lock out and got it functional again(was frozen). as much as I liked the school bus yellow I decided it was time for it to go.
BFR
Rocket Surgeon
2,330
42
North Georgia
note the two holes that are midway up the face of the bumper just outside the lift rings... Does anyone know what they are for? they appear to be punched.
BTW I went ahead and reused the 12 sholdered bolts that go into the winch. If anyone happens to have a short one(passenger side) they would like to sell pm me.
1,808
A winch sure changes the complexion of a deuce, especially from the front. I like it Joel, it's really coming along.
rmgill
14
Decatur, Ga
The extra length on the bumper and winch really make the deuce look more "boss" as a truck. They're quite impressive without a winch, add one and they just gain something more.
73m819
319
gainesville, ga.
joel, nice job, if you used the gasser front lift brackets ,you will have to bore them out to 1",(as there only have a 15/16" hole dia.) so you can use the towbar 1"pins and the 1"lift shackle pins, this way all will be the same size, thats why i have the 15/16" pins in the towbar ammo box so if i have to tow a 211,135,ect,or a gasser deuce, ill have the needed pins
rmgill
14
Decatur, Ga
Joel, McMaster Carr has Shoulder Bolts with hex caps. You should be able to find the right size and in Grade 8 or even Milspec.
