birddog1106
- 11
- 3
- southport,nc
Anyone used the above to make your bed dump ? Wondering how far forward from pins/hinge to place lift/cylinders........TU
You don`t think it would dump 10,000 on a 12 x8 bed ??The distance to place from the pins would entirely depend on how high you want to lift the bed. The lift of the bed would be minimal based on the actual specifications of the item that you want. The lift could be calculated from the overall height of the lift with the placement of the part combined with the placement of the rear pins. The image of the device on Amazon shows it gives a specific degree lift with the given tonnage promised.
If you want a lift bed that is more like a dump truck I would highly recommend simply designing one based on how other people do it on an industrial scale rather than going with this.
I make parts for the transportation industry, I've made thousands of parts for dump trucks, I would use this on a small trailer but not for anything that would actually see anything close to what it advertises.
Dump beds are typically built with the ram in the back for added stability. That device could very well be capable of lifting the weight that it says, but to get it to any moderate height it looks as if it would have to go very close to the pivot point. If I was going to build on for that much weight, which is a considerable amount of weight, I would design it like an actual dump bed.You don`t think it would dump 10,000 on a 12 x8 bed ??
Thanks for your reply.I will let you know how it works out---- I`m not doing the install.............VGDump beds are typically built with the ram in the back for added stability. That device could very well be capable of lifting the weight that it says, but to get it to any moderate height it looks as if it would have to go very close to the pivot point. If I was going to build on for that much weight, which is a considerable amount of weight, I would design it like an actual dump bed.
If you pivot that 12ft bed 12" from the end and mount that ram to achieve a rise of 8ft on the rear of the bed: with 11ft to the pivot point, you've only raised it to 36 degrees. If you want a 45 degree lift you have to go to 11ft.
When they design dump beds for dump trucks they usually build an enclosure at the back of the bed, and that is where the ram sits. This is for stability. Think of those mounting points as you would a tripod, if all three points are very close to each other, and you have a ton of weight leveraged off of the end of it, it will be far more unstable and dangerous. They don't make dump trucks with lifts like that because it is inherently unsafe.
You do realize this is a dump not lifting the bed ??...................VGThanks for your reply.I will let you know how it works out---- I`m not doing the install.............VG
If it's a dump bed it has to lift one side of the bed. I am familiar with them, having made parts for dump trucks for about a decade. I was merely questioning the safety of such a device used in this heavy duty application, as it seems more unstable than traditional dump bed designs which mount the ram in the back. This design is more like what you see on chipper bodies and light to medium duty trailers. I have been told I tend to over engineer and over build things, so take that as you may.You do realize this is a dump not lifting the bed ??...................VG
GREAT...........i`LL KEEP YOU N DA lOOP.................tu.....................vgIf it's a dump bed it has to lift one side of the bed. I am familiar with them, having made parts for dump trucks for about a decade. I was merely questioning the safety of such a device used in this heavy duty application, as it seems more unstable than traditional dump bed designs which mount the ram in the back. This design is more like what you see on chipper bodies and light to medium duty trailers. I have been told I tend to over engineer and over build things, so take that as you may.
In general between scissor and cylinder you might be right. I have spent the last day reading a large amount of things that agree with both of us, except in the area of actual weight capacity and weight distribution on the bed itself being significantly better with cylinder (but that's a metric of capacity and durability versus stability).M925 M925A2 dump bed hoist install
So... I've promised several people I would get this done for some time now. It may take me a little while, but I'm going to get pictures up, of my install of an old Knapheide manufactured, Knaphoist, KH-2520L that I found on the web for $400. I also ended up buying an old 15' dump bed, but...www.steelsoldiers.com
I think the idea that a scissor hoist is more unstable than a tower and telescoping cylinder is a myth. You want to be fairly level when dumping either.
are you taking into account that the dump bed on the m35a2 variant is significantly heavier and structurally much more significantly reinforced. it is one of the reasons that the sides of the dump bed are so short. it helps to restrict how much weight you can put in the bed and ultimately on the drivetrain, frame and suspension. that encourages "private jones" to not put five tons into a two and a half ton truck. not that it hasn't been done but the risks of something bad happening go up.
Yes,I agree not much strength in the sides also where can I find a wheel for a m35a3 ??.............TUare you taking into account that the dump bed on the m35a2 variant is significantly heavier and structurally much more significantly reinforced. it is one of the reasons that the sides of the dump bed are so short. it helps to restrict how much weight you can put in the bed and ultimately on the drivetrain, frame and suspension. that encourages "private jones" to not put five tons into a two and a half ton truck. not that it hasn't been done but the risks of something bad happening go up.
If you have sufficient privileges you can try posting in the Parts Wanted in Steel Soldiers Classifieds sectionYes,I agree not much strength in the sides also where can I find a wheel for a m35a3 ??.............TU
I called Eastern would u believe they want $ 975.00 CRAZY I don`t use them much I know white owl/Jim Henry have them. I ordered ,my O rings from George at White Owl .I just ordered Six 15.5-80-20`s and just wanted a Spare. Getting ready for HURRICANE SEASON !!.......TU........................VGIf you have sufficient privileges you can try posting in the Parts Wanted in Steel Soldiers Classifieds section
Depending on freight costs, might be worth it to check:
Boyce Equipment seems to have some in stock, in Utah.
Eastern Surplus is in Pa.
Big Mikes Motor Pool, he's in Southern New Jersey, doesn't show in stock so have to ask.
Few others, but their prices tend to go up a lot.
If you're not in a hurry, you can check out govplanet, might be able to get some good bids on some eventually in your neck of the woods, or with freight.
