FreightTrain
Banned
- 2,730
- 13
- 0
- Gadsden,Al
I know I read this somewhere but how do you adjust oilpressure on a deuce?Mine runs great(too great to actually be worn out) but the Oil pressure is a little lower than I would like.90% of the time it is right at 20PSI Cold,Hot,idle 2600RPM.The othe r10% is will dip down to about 10PSI at idle but normally it is sitting on 20 no matter what the speed or heat.This is with fresh 15/40 Rotella and was the same with the stuff that was in it from GL.I would feel a little more comfortable if I could shim or do something to get it to around 40-50PSI and I am sure my pistons would like more oil squirting the underside of them too.I don't want 120PSI or anything like that.I just know 20PSI is way low for an engine that actually runs good.
