Advice on M929 Dump Truck
tmuenster
99
TN
I am in the market for a heavy duty off-road dump truck to use at my property TN. The terrain is hilly, rocky and steep in places so I think a 6x6 would be ideal for moving dirt, rock, logs, etc. I am making some building pads and my dump trailer is not cutting it. The trailer sits too low to the ground and often gets stuck. The battery operated dump is also under powered for what I need to do.
I am thinking about the M929. Memphis Equipment has some great options for these dump trucks, including the extended wheel base truck that uses a full-sized 15 cubic yard commercial dump body. I am not sure the NHC 250 engine has enough grunt for the larger dump body but it would be nice to have the added capacity.
Please let me know if you have experience hauling dirt off road with the M929. Thank you!
tmuenster
99
TN
15yds of material is 45000 pounds depending on what it is and how wet it is. WAY TOO MUCH. 22.5 tons on a 5 ton truck.
Don't even consider that please.
Point well taken. There are some great resources online about buying your first dump truck. One thing I learned is the truck’s suspension is very important to safely operate the dump body. For example, over-the-road trucks can be converted with a dump body but it will still have the air bag suspension. When you have a heavy load raised to dump then all the weight is on the air bags. The truck can tip over if the ground is not level, a suspension bag fails or other problem occurs.
The standard M929 can operate safely for long periods of time in rough terrain. It seems like it would be a good fit for me. Thank you for your advice.
Jbulach
2,134
Sunman Indiana
M929 will make a fine farm hauler. You’ll be better off with the nhc250, the 8.3 has a hell of a time getting rolling, overloaded in high range, if it’s soft. You may want the first gen A0 with the dual wheels as well if you’re doing a lot of steep work, and still need to keep your cool and run straight up and down the hills.
fuzzytoaster
3,059
Fort Worth, Texas
The M917 dump can haul up to 20 yards of material but they're a rarer truck to find. They have a unique transmission by today's standards (CAT 7155) which has little to no commercial support and known problems with age. The Big Cam 400 is a strong engine and axles strong too. The issue falls with the transmission, the operator (again, unique transmission), and lack of transfer-case cooler on the M917s. They will cost more to obtain and more to maintain.
The M929s are well built 5-7 yard dumps and pretty tough. They are simple for the operator and maintenance with plenty of commercial support. I've had many M929/M929A1/M929A2 dumps come and go because everyone wants one. It's the ideal military dump truck in my opinion and seems to be commonly agreed upon. The engine debate of the NHC-250 vs 6CTA has been an old one and continues to be asked. The answer is - "it depends". What terrain do you plan to use it on? What experience (if any) do you have with either engine? What is available? What cost? That will give you the truck and engine you need. In the end they're all very similar in capability.
I have a clean M929A2 for sale in Dallas if interested.
tmuenster
99
TN
Thanks for all the advice regarding military dump trucks. After considering several options, I have decided to purchase a reconditioned M929 dump truck from Memphis Equipment.
The M929 is simple, rugged, dependable and should be ideally suited to use in a location that is hilly, rocky, and often muddy. I looked at a few used military dump trucks but I am sold on the process used by Memphis Equipment to recondition the trucks. The trucks are brought into their shop to be mechanically upgraded to include new fluids, filters, belts and hoses. The brake system is completely rebuilt to new. New batteries are installed. Tires 395/85R20 are upgraded to 80% tread and a spare is included. New upholstery is installed along with a new fiberglass hardtop. Finally, they perform any minor bodywork and paint the truck your choice of forest green or desert tan. They offer a 60 day replacement parts warranty is standard on every truck Memphis Equipment sells. Doug at Memphis Equipment was very helpful in the process and explained all the available options.
I plan to keep this truck for as long as I own the property so the added investment of a reconditioned truck works for me. I am also happy to support a sponsor of the Steel Soldiers community. I have a few military surplus items and Steel Soldiers is a great resource so I want to support those who support us. Memphis Equipment is about two hours from my farm, which was also a factor in deciding to buy my M929. I look forward to sharing updates on the project.
KN6KXR
550
Felton, CA
I have an M817 that belonged to a friend that passed and I bought from his widow for likely way too much. It's had a hard life the bumper is tweaked, the top of the bed over the cab (and the hard top) looks like he hit a tree with it at some point, currently missing the front winch PTO shaft.
It's a 1972 model with a sprag front axle engagement, manual transmission, NHC250. It can be really INTERESTING navigating downhill steep turns on dirt roads. Takes a knack. On road I don't think I've ever gone much over 50mph and hearing protection is more than advised. Bundle up in the winter it doesn't have a heater.
For all this.... character to the vehicle I really like it. It's short for what it is, I have it historically plated so costs me like $120/year and insurance is dirt cheap. For work on my property it's perfect. I may let it go after awhile as I don't use it much and have a smaller 3 yard dump I use more BUT I can see why they hold their value and can be hard to find when looking.
BEASTMASTER
142
Burgaw, N.C.
yep. i know what you mean , up north i used to put 100 miles on it in a month , been down here going on 9 yrs and aint put 500 mi on it, been thinking of selling it but it would be like cutting off my arm .
tmuenster
99
TN
Today, I had the pleasure of touring Memphis Equipment with company president, Mr. Doug Cummings. Doug has been an excellent resource as I considered all the options for a military grade, off road dump truck. I decided to purchase a M929 Dump Truck from Memphis Equipment and the tour was a chance to see their facility and finalize the options for my truck.
There are several reasons I decided on the M929 from Memphis Equipment. First, I like the fact that Memphis Equipment has been in the business of military surplus for over 70 years. They know the M900 series trucks very well. Their technicians recondition the trucks with an eye for typical areas for wear. All Memphis Equipment trucks come with a parts warranty, which is very impressive for a used truck. The trucks get fresh paint, new hoses/belts, fresh fluids, 80%+ tires, new batteries, new upholstery, and they are ready to go to work the day the new owner takes possession.
Second, Memphis Equipment has a very large parts inventory to ensure their reconditioned trucks are getting excellent parts. Their salvage yard is over 14 acres and they have several warehouses of NOS parts. It doesn’t hurt that Memphis Equipment is located about 2 hours from my farm where I will use the M929 dump truck.
Additionally, I am happy to support a business that is a Steel Soldiers sponsor. As a veteran, I enjoy having military surplus equipment. Steel Soldiers is a great resource to keep surplus equipment in operation.
Lastly, I would add that Memphis Equipment has done a lot over their history to repurpose miltiary equipment. I learned on my visit today that Memphis Equipment provides rugged, reconditioned equipment for many commercial applications. That’s a good thing for us as individual MV owners since we get to draft off of the commercial equipment users. The parts and tech support for the commercial surplus users has a direct impact on us as individual MV owners in my view. We are fortunate to have several surplus miltiary equipment dealers as sponsors for our community. I am sure the others do great work too and I hope to visit their shops in the future.
tmuenster
99
TN
Yesterday, I picked up my M929 5 Ton 6x6 Dump Truck at Memphis Equipment. The truck was ready to go and they spent some time with me going over the features and operation of the truck.
It was a great experience buying this truck from Memphis Equipment. The truck will be a simple, rugged and reliable dump truck for my unimproved property in Middle Tennessee. Memphis Equipment typically does not recommend driving the trucks home but my farm was only about 200 miles from their facility. It was a fun, slow drive on the back roads of TN to get the truck to my property. M929 are definitely for work and this is not the truck I would take out for a Sunday drive.
Here are a few features that I ordered with my M929-
  • M929 5 TON 6X6 DUMP TRUCK
  • CUMMINS NHC250 DIESEL ENGINE
  • ALLISON MT654 AUTOMATIC TRANSMISSION
  • NEW 12-VOLT ELECTRICAL SYSTEM WITH NEW BATTERIES
  • (2) CIGARETTE LIGHTERS FOR PHONE
  • CAB HARDTOP
  • GOOD USED 395/85R20 MUD AND SNOW TIRES
  • SPARE TIRE AND WHEEL
  • 20,000 LB. FRONT WINCH
  • NEW CAB AIR CONDITIONING
  • 5-CUBIC YARD DUMP BED WITH SIDE BOARDS
  • PINTLE/COMBO BALL HITCH
  • 4 WAY AND 7 WAY TRAILER CONNECTOR
  • NEW BACK-UP CAMERA
  • NEW UPHOLSTERY, HEATER, DEFROSTER
  • MECHANICALLY RECONDITIONED
  • PAINTED FOREST GREEN WITH BLACK GRILL, BUMPER, WINCH AND WHEELS
tmuenster
99
TN
My dump truck seemed naked without the proper markings. Needless to say, it will never be mistaken for an "Army Dump Truck" now. SeaBees! Can do!
19,629
I got to try out the dump truck today on my project in TN. It is a hoss. The 6x6 is very good but not invincible. I also got to try out the winch. 😉
Wow!
You didn't think that maybe you should stop churning before you buried it below the axles?
That winch is going to work hard to pull that loaded "Tipper" out of the mud...
tmuenster
99
TN
It wasn’t a case where I drove into the problem. We are excavating an area that has wet soil. We had taken a few loads out before I got stuck. I backed up the excavator, the truck was loaded, and it started to sink when I was pulling away. No big deal. It happens a lot with dirt work. As for the winch, I did let some cable out to attach to a bulldozer we have on site. The dozer did most of the work getting the truck out. We’ve had to pull out skidsteers, well trucks, a telehandler, semi trucks, and too many pickup trucks to count.
19,629
Guess it was good that you had a dozier to tie off to.
Went back and looked at the picture again - and there "ain't no trees" for you to tie off to!
Yeah, and it does look like it just sank down in the bog... Wow!
