wiersema07
- 3
- 8
- Illinois
Hello all
Have had a coolant leak since bought truck a week ago. I finally just pressure tested it and it’s leaking on both side tanks of radiator around the bolts. Also heater core box is leaking. I shut the valves to heater core but look likes the petcock valve for it towards from of engine it’s just twisting and not closing I believe. So I’m wondering if know a part number for that petcock valve. I’ll be posting multiple pictures.
what I’m wondering is it worth my time in buying cork gasket seal for both sides and putting rvt high temp gasket sealer all around and try and fix myself or at this rate just have a new radiator put in by a shop? And have them try and fix the heater core. It’s winter here and I don’t have a steel building to try and do this all inside nor really the time except on weekends
Also the block heater I bought is this circle freeze plug on passenger side of engine towards rear above the starter ? Before I try and knock it out .
thanks
thanks
