ODdave
- 38
- 0
- lansing michigan
Ok after lots of searching, on this site and others i have found a replacment 24V blower motor for the m35A2 deuce and a half with the hot water heat. Allthough it is not exactly the same, the only mods i see that where needed are for the ground wire to be atached externaly (closest bolt) and the power wire to have your existing lead (bullet conector) atached. But the most important mod is the much needed quick coat of some beutiful Olive Drab paint. the motor is NAPA pn. 655-1320 . cost was $31.09 + tax. the only part i am slightly questioning is the fan depth, although it looks fine i wont know untill it is mounted. i will find out in a few days and post it.
