Air Brake Leaking
barkster
Houston, TX
after I turn my truck off and have the spring brake set I can hear a small air leak on my back right air brake. It is leaking at location in picture. Could this be a seal or diaphragm? The brake is holding but wasn't sure if this was part of the spring brake or the air brake which was leaking. I assume the spring brake?? Safe to drive? Thanks
Coffey1
497
Gray Court SC
Warning Warning Will Roberson: There is a large spring in there that will KILL you if your not very very careful in what you do.
Stay safe
This has been a public service anounment.
Floridianson
2,500
Interlachen Fl.
Yea no worries. Just make sure the caging key is in good shape and it locks in with a quarter turn before you tighten the jam nut. Then just handle like its a loaded gun and don't point it at yourself or loved ones and all will be fine.
