Air comprssor belt adjustment
Tracer
14,094
Hawthorne, NV.
That bit of wisdom should be in the TMs.
You might be able to get away with just the top bracket and lean it forward enough. I also after putting on the new belt just leave the two jam bolts loose and start the motor and the pulley almost pulls all the slack out of the belt and is real close to right tight. Then tighten the two jam bolts and drink a beer.
