I ordered the rebuild kit and filter. This truck should be fully operational by
I ordered the filters and rebuild kit for the air dryer. In the meantime I've been starting the truck and draining the air tanks. I don't understand why water keeps coming out of the right side air tank, especially since i live in the high desert in Montana at 5700 foot elevation and its such a dry climate right now? I detached the main air line leading from the compressor but just air pumps out and no water. Also, when excess air pressure is relieved from the tires, water mist sprays out from the valves. I have fixed everything on this truck except for excess water in the right tank and the heater temperature pull handle that connects to the open and close valve under the hood. I can't pull the handle out, so I go under the hood and push the valve open with my finger, relatively easy. Then I go inside the cab and I can only push the handle to the off position. There doesn't seem to be anything wrong with the handle, the cable or the valve. I can push the heater temperature handle in, but I can't pull it open to increase the temperature.
