on my m931a1 the primary air pressure is 125psi, while the secondary is reading 135psi. i went through the trouble shooting tm's and only found info on what to do incase of overpressure on the primary. and i couldnt find a second governor for the secondary air side, so im assuming it all shares the same governor.
tonight i will adjust the governor so the secondary will read 130psi, but then the primary will probably read 120psi, which is technically fine. but its just annoying that they're not the same. also tonight ill flip the air lines to the gauges and see if its reading the same just to check themselves. but any other ideas?
